1977 Fiat 124 Spider Hand Brake System
My handbrake doesn't ratchet up and hold. Inspection doesn't reveal the cause. The ratchet gear is there; the ratchet post engages but doesn't lock. Could not find any replacement parts for the assembly. Did find the ratchet description and perhaps the part number, but no one indicated they had the part. Would filing the ratchet gear fix the problem? What do I do to the Post? Any help is appreciated. Tom Mock
- Your car is a: 1976 124CS1 Spider
Re: 1977 Fiat 124 Spider Hand Brake System
I'm pretty sure they are all the same...I can pull the one off my '71 parts car....$25 plus $12 USPS shipping if interested.tommock wrote:My handbrake doesn't ratchet up and hold. Inspection doesn't reveal the cause. The ratchet gear is there; the ratchet post engages but doesn't lock. Could not find any replacement parts for the assembly. Did find the ratchet description and perhaps the part number, but no one indicated they had the part. Would filing the ratchet gear fix the problem? What do I do to the Post? Any help is appreciated. Tom Mock
- maytag
i think we should move this out of the "discussion about this site" forum.
