1981 Restoration
Re: 1981 Restoration
Some shots of the engine s l o w l y coming back together....
http://i839.photobucket.com/albums/zz31 ... 0216-1.jpg
http://i839.photobucket.com/albums/zz31 ... 0215-1.jpg
http://i839.photobucket.com/albums/zz31 ... 0218-1.jpg
One bolt at a time.....
Absolutely wonderful engine restoration! My hat's off to you Sir!
Riccardo
Riccardo
Thanks! But the real test is will it start and run
I will find out in a month or so......
So....head is complete with Marks 274fi cams. Block is all back together......aux shaft lobe is off!
Question...I have Millers adjustable cam wheels with no marking. Before I slap the two together, how should everything be adjusted? Anything else?
Robert
Robert
- 124JOE
from you pics i see the motor was not at TDC
it should have been set to TDC before you put on the head
when putting the head on you want them set to #1 intake about to open and exh just closed
as for the aux,put on the original pully,set it,then change and mark it
Joe - I had just placed the head on for looks
#4 is at TDC now. Thanks for the info on the cam. Also, my AUX has no lobe so I don't think I need to worry about its location.
Robert
Robert
- 124JOE
ok but the aux has to line up with the oil pasages
if it had a lobe it would be for a mecanical fuel pump
it needs to be at the 1oclock so it can oil the head and block
Great....I just put the friggin timing belt on......another step back!
http://i839.photobucket.com/albums/zz31 ... ngine1.jpg
http://i839.photobucket.com/albums/zz31 ... engine.jpg
Only thing left is the injectors once the new small seals arrive!
- 124JOE
looking real nice there drivers
- Your car is a: 1975 Spider
sorry this is bad information, there is no timing for the aux shaft except for the fuel pump lobe to miss the crankshaft/rod124JOE wrote:ok but the aux has to line up with the oil pasages
there are no oil passages that require timing!
son has 78 spider
son has 78 spider
by the way, great looking work. looks as things are coming together nicely for you
son has 78 spider
son has 78 spider
- 124JOE
so then you olny need to set the aux shaft if you using a mecanical pump?
Yeup. If you have wacked the lobe off and plugged the oil galley, no need to worry about contacting #2 rod. Set the aux where ever you like then.124JOE wrote:so then you olny need to set the aux shaft if you using a mecanical pump?
