Removing bezels
74ausfiat
Removing bezels
Post by 74ausfiat »
is there a smart way to remove the bezels around my tach, speedometer etc. without hurting the wood?
i guess just a glue solvent and a thin flat head screwdriver?
thanks!!
azruss
Re: Removing bezels
Post by azruss »
you need to remove the gage panel and remove the tach from the panel. it is held to the wood with 3 screws. once the tach is out, you can carefully pry open the crimp on the bezel.
74ausfiat
Re: Removing bezels
Post by 74ausfiat »
ahh ok so are all the bezels crimped on?
if so... pretty fancy.
azruss
Re: Removing bezels
Post by azruss »
here is what you are looking at.
74ausfiat
Re: Removing bezels
Post by 74ausfiat »
hahah jeez thats a lot of stuff to remove just to refinish the front of this thing. haha. thanks for the photos. at least i know what to expect when pulling that thing off!
azruss
Re: Removing bezels
Post by azruss »
you really dont need to remove the entire cluster. with some patience you can pull the panel out enough to get your fingers in there and undo the 2 screws and unplug it.
74ausfiat
Re: Removing bezels
Post by 74ausfiat »
Well I'm going to be resurfacing the whole wood panel . Or replacing it entirely so I gotta get those bad boys off of it
124JOE
Re: Removing bezels
Post by 124JOE »
i remove the two 13 mm bolts that hold the STcolum
so it drops enuff to remove the dash pannel
74ausfiat
Re: Removing bezels
Post by 74ausfiat »
ive actually decided to replace the wood dash cluster with a metal one i got from a member here. once i unscrew the backing on these gauges do i push them thru the front of the panel orrr?
thanks!
124JOE
Re: Removing bezels
Post by 124JOE »
74ausfiat wrote:ive actually decided to replace the wood dash cluster with a metal one i got from a member here. once i unscrew the backing on these gauges do i push them thru the front of the panel orrr?
thanks!
yes
chico
Re: Removing bezels
Post by chico »
Fastest quickest way I found was to remove the top of the steering column cover, 4 screws on bottom side of column cover. Then you should be able to pull the gauges toward yourself and remove the one nut that holds the gas gauge in place. With that gauge removed you will be able to remove your odometer cable and then the 2 main plugs for the front gauge. just gently pull the whole thing toward yourself and slide it out. Hope this helps just finished re doing my front console.
74ausfiat
Re: Removing bezels
Post by 74ausfiat »
Yea it turned out to be super simple. Thanks everyone !
