But for the same engine speed, the plex 201 still cannot advance spark at low loads, right? If so, that was the point I was trying to make between getting a plex (which I'm sure is an awesome addition) and using a ported vac for the Marelli dizzy.bradartigue wrote:A plex 201 was the same distributor without the vacuum porting, it was all mechanical. That's what I mean by not having mess around with porting
That carb wasn't designed for the distributor port, that isn't what the "A" means anyway. A meant "America" or more precisely "American Emission Controls" and they were different in California and the USA.
DMS A had a choke limiter, secondary throttle limiter, and a high idle device......
As far as the DMS vs DMSA, one other thing I always thought the "A" brings you (at least with that model Weber) is the ported vacuum. I mean, at least according to the Weber diagrams for the DMS and DMSA. So, I made the leap that the "A" for "America(n)" emissions also means a ported vac for EGR and/or vac advance dizzy (as fuel economy and emissions are directly related).
BTW, what's the secondary throttle limiter?
