Well stated. I hope no offense is taken, because you said that very well.seabeelt wrote:Not to be too critical of the writer, but it seems like you are writing using my kids text messaging shortcuts for words which us older folks are having a hard time deciphering. If you could use distinct clear sentances with at least some punctuation, that might help. If its a language thing then perhaps use one of those on-line free translation programs..... Then I would work on the chronological logic of your problem and steps taken to correct the problems. The overall description that I can manage so far is that you have unequal cylinder pressure after a rebuild. Lets start with what you did on the rebuild, then progress to how long you drove it before you had issues with compression and then what steps you have taken to analyze and fix the issues....We are here to support you, but its really hard to follow your post.
I would like to emphasize again that until the head bolts are repaired, it is foolish to chase compression issues.
the broken head-bolts are ABSOLUTELY RELATED to the compression in each cylinder.
