1981 Fiat Spider 2000 - What am I doing!? LOL!!
124JOE
Re: 1981 Fiat Spider 2000 - What am I doing!? LOL!!
Post by 124JOE »
if and this is a big if,because it in GM and FORD
you hooked up a power wire for the stereo to the auto dim wire THIS will give power to the light system
just a thought
so if you were under the center consloe or hooking up the stereo
recheck what you did
keep going
as i said before along time ago
you need a friend thats in love with the car to help you
and the hard part is timing the help with yours
jimmycakes401
Post by jimmycakes401 »
Nope. Haven't wired anything else. I like to do one thing at a time. The only thing I did was hook up the hazard switch. BUT. I do have an idea and will go check it in a few minutes.
jimmycakes401
After much fighting and searching my lights are all resolved.
NOW! What kind of fastener is used to attach my console down by the footwell. Seems like a big hole. Is it like a giant sheet metal screw or a bolt??
I need to get this interior in so I can get it squared at the DMV and on the road!! Wooo!!!!! :D
124JOE
Post by 124JOE »
mine has screws
tapered head philips
jimmycakes401
Perfect. Will grab them tomorrow. And two big washers. And then something to screw near the brake as well as bolts to attach the top to the bottom. Amazing how long it takes to gather up missing bits.
jimmycakes401
Just a quick update. Hopefully a little time will open up to get some work done so I can get this thing out on the road!!
http://fiatspider.weebly.com/1/post/201 ... pdate.html
jimmycakes401
Ughhh... So I bought piles of screws and bolts to get this interior together. It's coming together slowly. But I'm having trouble with the driver's side kick panel with the speaker in it. My screw holes aren't lining up. They aren't just a little off. They are like .5" too high! What the heck!? Any thoughts? My carpet isn't all that thick. I did put a tiny bit of padding, but not .5"!
124JOE
Post by 124JOE »
thats ok,these cars were hand built
so you can drill new holes if needed for a better look and fit
jimmycakes401
I just picked up my battery. I'm getting close. The negative cable is too small for the terminal. What's that all about? Maybe I need to stretch it out more? I don't know. Maybe I need a different cable. Didn't need any help with the positive. Also, the bolt is an 8mm on the negative whereas the positive is 10mm.... wonder if the PO replaced the negative but never used it...
4uall
Post by 4uall »
Ahhh yes the dreaded negative battery cable
SOB! Negative terminal disconnected by itzebtze, on Flickr
hmmmmm what's under that tape? by itzebtze, on Flickr
A hidden treasure under the electrical tape by itzebtze, on Flickr
jimmycakes401
Good news....
They are tapered and I was putting it on upside down. LOL!!!! :lol:
jimmycakes401
So. Just about ready to get on the road. Just need to
  • modify upper console for new radio then install consoles
    put seats in
    put the shifter back together
    bolt in the new exhaust center section
    put in a light bulb
    fill out paperwork
Then I think I can drive off. Oh... I should learn how to drive stick too.
124JOE
Post by 124JOE »
for my radio i screwed the sleeve for the radio to the bar above
this holds the radio firm
my console has a large hole that i will cover(the sides and bottom) with black sticky backed flooring,cut to size
jimmycakes401
I have the two tiny circle holes and the small rectangle.
124JOE
Post by 124JOE »
thats for the old style with knobs
mine has been cut out big
for the new style cd player
