Engine aligned at TDC #4, plugs out, in first gear, rear brake set.
1.) Bought (2) chain wrenches at Harbor freight Tools. (They are 1/2" socket drive). Needed (2) because (1) is just a little too short to get around the larger pulley on the crankshaft. Drive a pin out of the chain section on one of them and add the chain to the other and it will reach.
1a.) You need to remove the retaining bolt on the timing pointer and rotate it back out of the way to get the chain wrench wrapped around the pulley. The lower point is a permanent pivot so it will rotate back into proper position when done.
2.) Bought the longest 1/2" drive breaker they had (~24").
3.) Then you have to file out the receiver on the chain wrench because it is under 1/2" due to paint and stamping process. I got the breaker bar onto the chain wrench eventually by putting it all in a vice and forcing it together, and got it apart by driving the bar out with a drift pin when needed after the job was done.
4.) Add a 4 ft. piece of 1" ID black iron pipe from Home Depot slipped over the breaker bar and you have the chain wrench ready to hold onto the pulley:
Now for the socket:
1.) Got a 38mm socket at HFT, had to buy a set to get this particular size but it wasn't expensive.
2.) This socket is a 3/4 drive, bought the biggest 3/4 drive breaker bar they had (~24"). Diameter of the breaker bar shaft is ~.980"
3.) Add another 4ft. piece of 1" ID black iron pipe over this bar and you have the driver setup.
Then I tried doing the turning alone and couldn't get it to budge. Waited for my 15 y/o to come home from school and he took the chain wrench bar and I took the socket and after a few major pulls, I heard a "click" and the GD nut was free.
What a production, took 1/2 a day to get this far. But it is now loose!
Also soaked everything in PB blaster ahead of time.
