To be or not to be repaired?
babu2001
Post by babu2001 »
Here's a picture of my steering wheel. It began to make noise and I found rapidly the problem :
Is it possible to repair it with a VERY small needle to inject some epoxy? I would like to repair it but if the chances are near zero, I won't waste my time. Personnaly, I don't think it will work. Yeah, you can call me pessimistic... :wink:
Re: To be or not to be repaired?
I had a customer use dental implant putty to repair one. He sanded and painted it afterwards and it looked perfect
124cso
Post by 124cso »
There should be a ring of about 1/4" rod/wire forming the wheel as a base for the synthetic woodlike rim, so a cosmetic repair should not reduce wheel strength.
Is that a leather seat ??
babu2001
Post by babu2001 »
Since I've checked for replacement and the cost is ... costly. :cry: I'll give it a try. The odds are not to good but it's not a big job either. I have to choose between liquid epoxy or Gorilla glue. Gorilla is more liquid and likely to go everywhere. Other suggestion? (I don't have a dentist among my friends... :D ) And yes, the seats are made from leather. Aren't all Azzura made from leather? :? These one were blue at first but very well black tainted.
vandor
Post by vandor »
Yes, but they did not have a wood wheel :-) So likely it was assumed you have an earlier Spider.
124cso
Post by 124cso »
Thankyou Vandor for that quip.
Not sure how it should be spelt but "Too-shay" ? Mr bandarras AKA Puss-in-boots would know !
Just realised this is the guy saying he could not turn the wheels while the car stationary (unless he put lots of effort into the wheel) Twang. Ooops !
onemorespyder
Post by onemorespyder »
Gorrilla Glue, while pretty strong, is porous when cured so would make a much more noticable repair. Epoxy to bond the bits back together then a good epoxy based filler would be less noticable I recently bought a 'wood' wheel on EBay for 39.99 that looks great so maybe just a change. You surely should check your steering box and reduce the steering effort before any change or repair so it doesn't happen again!
Regards, Darrell
baltobernie
Post by baltobernie »
The two-part marine-style epoxy will work in this application. If you mask right up to both sides of the crack, excess epoxy can be removed before it hardens. Testors makes a plastic model jar paint that matches your woodgrain very well. Look in a local hobby shop.
Having said this, the aftermarket wheels are smaller than the "hula hoop" OEM ones. Makes a huge difference in leg comfort. ingress and egress, and the ability to remove the cluster :idea:
