Put the trunk lock assembly back together - pictures? 1981
jimmycakes401
Post by jimmycakes401 »
The PO removed the whole lock assembly from the rear. Latch and all. I gathered up what I think are all the parts. Just not sure how it all goes together. I also don't know how to keep the tumbler in my 2000 zero. I can see that there is a metal thing that goes on the back of the tumbler which must have been held on by some sort of clamp. Then the plastic arm must go over to the latch assembly and bolt on. Not sure how the arm is supposed to be situated. Also not sure what direction the metal thing on the back of the tumbler goes. I figured out the spring. : )
124JOE
Re: Put the trunk lock assembly back together - pictures? 1981
Post by 124JOE »
the bracket points straight down when locked
heres some pics
ofcorse this is a 78 not a 2000
on the plastic bar there was a plastic peg that whent into the locks rear bracket
it went bad so i drilled it out and put a bolt in its place with a wing nut
jimmycakes401
That answers just about every one of my questions. Wonder if a standard hardware store would have that "C" clip... I guess that's all I need. And some nuts.
jimmycakes401
Is your's a 1981? I'm not sure if I have room for a nut and a wingnut. Got the C clip and popped it on. Seems like it's working.
124JOE
Post by 124JOE »
on the plastic bar on the lock side it had a snap peg .it was bad
i cut it off and drilled it out
then put a bolt thru the bracket and nut with wing nut on the bolt
its a 78
spider2081
Patron 2024
Patron 2024
Post by spider2081 »
I picked up a pack of assorted clips at Harbor Freight and one in that kit fit my 81 lock.
jimmycakes401
Yep. I put the back thing on upside down. Good to go.now ! Big help!! Thanks again. I need to blog this up.
