Paint Code - Grigio fumo Met
- courtenay
Does anyone know what a current paint code/paint manufacturer would be for Grigio Fumo Met? The tag on the underside of my trunk lid says 899F, but I'm not sure what that means.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
- Your car is a: 1980 spider [carb]
Re: Paint Code - Grigio fumo Met
The color of your car is the same as mine. I've never seen another one, so that makes two of us. I got a small bottle of touch up paint from carpaintonline.com. It's their number 33399.
1979 Spider
2001Saab SW
2004 Saab Aero
2001Saab SW
2004 Saab Aero
I guess I'm not aa exclusive as I thought. I wonder what the most common color is? I'm guessing red.
1979 Spider
2001Saab SW
2004 Saab Aero
2001Saab SW
2004 Saab Aero
- courtenay
Thanks for the tip on carpaintonline.com, Don. I ordered a 12 oz can of touch up spray last night which should take care of the problem.
Question, though, is how I should prepare the surface of the door lid before I spray it?
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
Can't help you there. All I know how to do is touch up little knicks with the built in brush under the cap.
1979 Spider
2001Saab SW
2004 Saab Aero
2001Saab SW
2004 Saab Aero
- 124ADDHE
- Your car is a: 1974 Spider Amalgamation with C40 Solex
Bruce, this is the order for painting:
1- degrease (cantire)
2- sand with 600 grit.
3- degrease or soap and water
4- Prime if bare metal exposed
5- Sand if needed and clean again
6- Lay a light/med first coat
7- med coat
8- med coat
9- congrats, your done
7- med coat
8- med coat
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
- courtenay
Thanks, Keith. Is the "degrease" at Canadian Tire labeled as such - and in the auto paint department? Can I use rattle can primer - again, Cantire?
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
- 124ADDHE
Yes Bruce, cantire has an automotive degreaser. Some primers are better than others, they do sell an epoxy primer in a rattle can that seems great, im sure not as good as a 2 part system from the pro supply store (which is a great place for paint and advice if you have an autobody supply store in your community).
P.s. the degreaser takes forever and a day to evaporate, apply with one rag or a sprayer and then wipe clean with a different rag, also this stuff is nasty for any kids or pregnant women, i always make sure and at least use a respirator.
Looks like another beautiful top down day
Regards,
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Also, if I were you I'd shake the can real well; this is a metalic paint and I noticed all the little metal flakes had to be stirred up from where they setteld at the bottom of my little touch up bottle.
1979 Spider
2001Saab SW
2004 Saab Aero
2001Saab SW
2004 Saab Aero
- 124JOE
you can spray the paint into a container and brush it on in small areas,like nicks/chips and cracks to seal it up
i use a baggie
theres no over spray this way
i use a baggie
