IGNITION LOCK
- Your car is a: 1982 124 spyder
IGNITION LOCK
Can anyone tell me the trick to extracting the ignition lock from a 1982 spider?
Re: IGNITION LOCK
yes. you need to turn the key in a certain position while pulling everything out and press the plate on the side of the lock at the same time
Re: IGNITION LOCK
This is from my manual, might help. I assume it applies to '82:
Pete
Pete
Re: IGNITION LOCK
Thank you gentlemen - worked like a charm
