1981 Fiat Spider 2000 - What am I doing!? LOL!!
- 124JOE
Re: 1981 Fiat Spider 2000 - What am I doing!? LOL!!
open the cap and squeez the hoses then fill
the heater core needs to be open
some day install a flushing tee on the upper heater core hose
and drill a 1/8th hole in the thermostat disk
I understand installing a T in the hose for flushing and venting, but why would you drill an 1/8" hole in the thermostat disk?
It lets trapped air get past the disk, assists with bleeding the system. Doesn't significantly effect overall function.
I think I drilled a 3/32" hole. Worked out great.
Anyone know how far away the E-brake line is supposed to be from my exhaust? Mine is right up against it and if I don't fix it, it will melt. My exhaust is nice and tight up against the body. It's not loose or dangling. If I fiddle with the ebrake cable it will hang about .5"-1" below the pipe. But I feel like it works its way back up to the pipe. Bare in mind, I'm not on the road yet.
- Your car is a: 1975 Spider
the emergency brake cable routing is a factory defect!, the cable was to be about a inch from the exhaust in a perfect world, there is no support to keep it there, the support provided does help, but not much. My personal recommendation is to get a piece of Aeroquip firesleave, or a plug wire covering from a race shop. Slide this down the handbrake cable to protect it from the heat and contact. Works great on my car and has for 10 years
son has 78 spider
son has 78 spider
I had a feeling that was the fix. Thanks!
Thanks. I'll try with more force tonight on squeezing it. I got some weird genetic house that has metal wound in it and it's really hard to squeeze, but I'll give that a try. Already have the flushing T . I understand the drilling part now, it's the disk inside the thermostat right? Makes more sense.
Have you followed these instructions?
http://farm7.staticflickr.com/6228/6381 ... e3a4_z.jpg
oh, I'm not FI... but for the first step, it seems like I'd still wind up with air in the tube when you connect 1 back to 2 and I don't have the bleeder plug.
I didn't do 1 to 2. LOL. SHhhhhhh
But I did jack up the front with the top of the radiator off and run it. It didn't burp much. I guess it was pretty well full to begin with. I will install a burp T when I put in my new heater core. I'm an expert now when it comes to taking apart my hoses and heater core.
haha, I won't tell. Ya, I was thinking about it earlier, I need to get a bigger incline, my jack doesn't get the car high enough. I guess I'll give the ramps a go again.
I wanted to use ramps, but it's not an option at the moment.
I know I sound like a broken record however, I do not have a T installed and I was able to follow these instruction while on flat ground and I had no issues ever sincejimmycakes401 wrote:Have you followed these instructions?
http://wwwe.fiatspider.com/f08/viewtopi ... =5&t=16398
I did it on flat ground too. I figured it would work fine, but as an extra precaution I did the raised burp as well. Mainly because I bypassed the heater core and was concerned that maybe one of my hoses was a little higher than normal. I only go one tiny burp when it was raised, so I know I did a good job to start out. Also, I just posted the picture of those instructions.
