ATTENTION ALL AUSTRALIAN 124 OWNERS
ch33kster
Post by ch33kster »
Please please please help me!
Does anybody have any suggestions for the best way to make the throttle cable work / travel and function properly on a right hand drive conversion.
Photo's / illustrations and ALL suggestions would be GREATLY APPRECIATED!!!
My head hurts thinking about it!
Thanks in advance,
Charles
1969 AS Fiat 124 Spider - HUM 366G -
perthling
Re: ATTENTION ALL AUSTRALIAN 124 OWNERS
Post by perthling »
You will need a RHD cable, and the cable will run from the firewall across the top of the cam boxes to a bracket (varies depending on what kind of carby/ies you are running). Shouldn't be difficult as long as you can procure/make the brackets. This was the arrangement used on RHD coupes. I don't have any photos at present but will hopefully be replacing the clutch cable on one of my Coupes this weekend so will take photos if I remember.
_______________________
Perthling
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
http://www.fiatlancia.org.au
Curly
Your car is a: 1968 AC Coupe and a 1976 CS1 Spider
Post by Curly »
G'day Charles, I posted a pic of SPYDUH's twin carb setup in the other thread on 'Engines', but here's a shot of her before she went with twins. The green cable is the throttle cable.
Here's a different twin carb set up that I use on the coupe, it's a simple home-made bracket attached to the cam box to hold the end of the cable. I hope this helps you out.
