I've cross-threaded one of the brake-line ends into the "splitter" fitting that's located near the rear axle (don't know what this part is called, but the brakeline from the compensator connects to this fitting and sends brake fluid to each of the 2 rear break calipers). I need to either replace this fitting, or re-tap the female threads that were damaged. Anyone know what this part is called and where to get it? Or, what size tap is needed to cleanup the threads?
Brake Parts for 1978 Spider
Re: Brake Parts for 1978 Spider
It's available new from us:
http://www.autoricambi.us/cgi/commerce. ... ey=BR4-458
If you need the metal brake line, I have several used ones.
