Rubber bumper corners
I'm trying to remove as much as I can for my soon to come paint job. How do I get the rubber corner sections off the (pipe style) bumper on my '78? Also, any advice on removing the door handles and side marker lights?
TIA!
TIA!
- 124JOE
Re: Rubber bumper corners
theres covers on the back side of the bumpers,remove them
unbolt the bumper
if you brake a stud you screwed
pretreat with PB blaster.youll see how they unbolt
door handles are nuts on the inside of door
remove the skin and look for them (2)
the side markers are nutted from the bak also
7mm i think
again use PB blaster and let sit 1 hour at least and go slow
unbolt the bumper
7mm i think
Thanks, Joe. I'll try the bumpers tonight. Got the side markers off quite easily. They are all intact and in good shape for having been on there for 34 years. Didn't realize they were plastic, though.124JOE wrote:theres covers on the back side of the bumpers,remove them
unbolt the bumper
7mm i think
OK, instaed of messing around with trying to just remove the rubber corners, I'd like to just remove the entire front/rear bumpers. Looking underneath the front, I see what appears to be a bracket where the bumper shock goes in to. It looks to be held on with 3 or 4 bolts. Will removing these bolts release the whole bumper assembly? The rear is another issue. No idea how they are attached as I haven't yet looked for access to them. Anything I need to onow before I tackle them this weekend?
TIA...again!
TIA...again!
- 124JOE
leave the brackets on
just remove the big bolt
one per side
the rear drivers side has the tank in the way because the bolts are from the inside
so on that one remove the shock bolts from the bumper
one per side
Cool! Thanks, I'll give that a shot. By "big bolt", do you mean the one that looks like it goes right through the piston/shock thingie?124JOE wrote:leave the brackets on
one per side
- 124JOE
yes remove one from each side and disconnect the lights and pull it off,
its heavy get some help.
on the rear, remove the tire in the trunk and then the bolt on pass side
last remove the small bolts from the bumper to the shock on the drivers side
Well, that didn't work, LOL! I removed the big bolt which goes through the end of the shock, both sides.I put jack stands under each side to help with support. I could shake the bumper and it's loose, but it looks to be still attached by a "U" bracket, inside of which is a big rubber bushing. I didn't have the energy to try and remove those tonight, and I'm not even sure that would do the trick.124JOE wrote:yes remove one from each side and disconnect the lights and pull it off,
Maybe tomorrow night?
- 124JOE
mabey best of luck to ya
Got the front bumpers loosened. Question: How/where do the blinkers unplug?
- 124JOE
i dont think the wires have a plug you need to unbolt the housings from the bumper
- DocGraphics
Yes the blinkers do unplug but you have to follow the wires up thru the inner fender area above the tire, thru a grommet into the engine compartment, unplug wires/connectors there & feed them back thru the grommet to the inside of the fender, etc.
Don Raugust
- 124JOE
oh thanks
