My floor clean up and general interior sprucing up is coming down the homestretch. But yesterday I came across a problem that could leave a detail undone, unless some one in the Community can help me with a little part.
Next to the fan switch on my lower console (1976) is another opening where a little clear indicator that says "DEF FAN" is inserted and attached to a fiber optic wire. I've got the indicator but I don't have the insert it fits into. The hole has always been there and I hoped that when I pulled the console I'd fine it underneith, but no such luck.
Here is a picture of the console, the indicator, and the hole where the indicator holder goes. Does anyone have one of these to spare?
Help with a Little Part
Re: Help with a Little Part
I think that that little clear plasic piece fits into the center console slot by itself and is a snap fit item. On an 82 it is verticle with the fan switch on the side not horizontal across the top so it could be different on your car. I would suspect that you would install it from the underside. With that said a dab of glue may do. I think that piece on my car will surface from under the console at some point when I need to go there again.
I like the green with white stiching. What color are the seats and dash?
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
TX82
No it definitely has some sort of a surround, probably black like the surround of the fan switch. The photo is decieving. The clear piece is much smaller than the opening.
Here's a pic of the interior.
There is a black thingy that slips in from the top that has two prongs that hold that in place. I do not have an extra one, but I saw it this week while working on my interior.
