Hi can anyone give me an idea on how too reattach the cloth that runs along the back bow near the window, it has come apart so when I lower the roof it does not go down together with the top have to help push down on it, when I raise the top it goes way forward have to push back on it to lock in the tension on the back window. Any type of glues out there that can be used to glue the cloth to the vinyl top.
Nick
Bow on top not attached
- Your car is a: 1979 Fiat 2000
- 124JOE
Re: Bow on top not attached
theres supose to be a plastic cap to hold the fabric to the bows
they were sewed on
mine ,was missing and the last bow fell
or sliped back to the window all the time
it drove me NUTS
so i tied string from the mid bow to the last bow to hold it up
untill i replaced the top frame form an old car that all the parts
they were sewed on
it drove me NUTS
That string thing is a GREAT IDEA! I have the same problem which I'm sure will be fixed when I eventually get a new top. Maybe something a little classier than a string though. Maybe a COACH string!
- 124JOE
i still have the old frame and it still has the string on it
it didnt keep it from moving forward just form moving back to the window
Hey 124JOE sounds better good on what you did with the string. Would you be able to post a picture of the frame with the string still attached.
Nick
Nick
- 124JOE
its in storage but yes ill try
- wachuko
- Contact:
The string tip is a great idead! Never thought about something like that. You keep the correct distance and the front bow pulls the rear bow in place. Neat. I have a new top now, so I hope I don't have to implement that workaround any time soon, but great tip!
Nibbes123,
Did the flap came unglued or completely apart from the top?? If just unglued, you can use some contact cement or 3M adhesive to glue it back.
Here are a few photos from my build thread:
Flaps glued around the bows and plastic trim installed:
I centered the bow on the middle of the flaps, where you see the stitching. I then sprayed the flaps on the inside with some 3M Spray Adhesive. I sprayed closed to the flap, but just in case, I covered the window to avoid any glue overspray from reaching it...
Plastic trim. Just snap it in place.
All plastic trim for the bows installed...
Nibbes123,
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
Hey wachuko the flap came totally apart . Sorry for getting back this late was out all day in the 20C in Toronto.
- Patron 2024
- Your car is a: 1973 spider refurbished
My top doesn't have any of the plastic trim pieces. I never knew there were such a part until your pictures. Are these available anywhere?
Yeah, I've never seen those either. Must have been on the 80's Spiders. Definitely not on earlier ones. I wonder if they are available.
- spidernut
I've personally not seen them on cars older than 1979. My 79, 80 and 81 all had them. Bruce's Parts Bin had replacement bow covers. I don't know if he still does or not. I haven't heard from him in a while.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
