My 81 Spider 2000 is being painted and I would like to reinstall the original side moldings. They were riveted on with a vinyl insert. The vinyl is badly weathered and I would like to replace with new.
Does anyone know where I might purchase the moldings new???
original side trim molding
- Patron 2024
Re: original side trim molding
those were dealer installed, so there are many varieties floating around
- Patron 2024
I don't have them here to take a photo. I guess that is what I need to try next.
Thanks Mark for the info
- Your car is a: SOLD
This site has vinyl insert moldings for rivet-on trim: http://www.customautotrim.com/products/ ... /rivet.htm
Looks like they only have black, white, and silver inserts. You may be able to dye or paint the vinyl to a desired color as long as you prep the material properly so you get a long-lasting result.
So Cal Mark is right... there were a lot of variations. Hopefully the site above has a match for you.
Good luck!
Good luck!
SunnySideUp
- Patron 2024
Thanks I called and they are sending a sample. It looks identical to what I have. The insert on mine is a light blue and is really in bad shape. My car is the dark blue metallic so I think the silver will look great. Thanks for you help.
You might want to try Deluxe Auto Molding in Chatsworth, CA phone 818 718-7600 (no website); JC Whitney used to sell their product and it was available in several vinyl colors which pressed into the aluminum molding (screwed or riveted to the body). If you use this type of molding, be sure to make the vinyl strip a little long as will shrink some with time and you will then have a small gap to the tapered end cap.
Warren
Sylacauga Alabama
1979 Fiat Spider Automatic
1991 Alfa Romeo Spider Veloce
1974 Dodge Dart Sport Hang 10 (in restoration)
Multiple other cars, trucks, and boats
Sylacauga Alabama
- Patron 2024
Thanks warren tried calling but its some energy co phone # Looked in yellow pages and can't find the company
Maybe they moved to this location:
Deluxe Auto Molding
(818) 989-9899
16000 Strathern St
Van Nuys, CA 91406
Get Map & Directions »
Neighborhoods: North Hills West, North
Good luck....
Deluxe Auto Molding
(818) 989-9899
16000 Strathern St
Van Nuys, CA 91406
Good luck....
Warren
Sylacauga Alabama
Sylacauga Alabama
