Dash Lights not working
contrevi
Post by contrevi »
I replaced bulbs and fuses dash lights still do not work. Any Ideas?
124JOE
Re: Dash Lights not working
Post by 124JOE »
the reostat in the dash
was it unpluged?
or mabey its dirty
but first thing is check the grounds
geno58
Post by geno58 »
I had that problem, I bypassed the reostat, problem solved. I don't need to dim the dash lights, their fine full on.
Good idea. I think I will bypass the Rheo too, it is completely unnecessary. Just another potential failure point.
MrWampus
Your car is a: 1981 Spider
Post by MrWampus »
Yep, same problem here. No dash lights except for headlight and high-beam indicators. Traced it to the dimmer, bypassed the dimmer, now I have nice illumination. They are not overly bright anyway, so I'm going to leave it.
1981 Spider "The Mistress"
http://s1088.photobucket.com/albums/i329/mrwampus1/
"Because a 30-year-old sports car is cheaper than a 30-year-old blonde."
contrevi
Post by contrevi »
How do I get to the reostat? Throught the dash behind the gauges?
VC
geno58
Post by geno58 »
I pulled the upper consoled, the one with the radio in it. I just took the screws out, and tipped it forward. You can remove the switch to make it easier to work on and then once you bypass the switch, put the switch back in the hole.
