Weber 32/36 DFEV Upgrade: Game, but Ignorant
opus10583
Your car is a: 1978 CS1
Re: Weber 32/36 DFEV Upgrade: Game, but Ignorant
Post by opus10583 »
manoa matt wrote:[...]
The EMPI air filter housing will come with the appropriate crank case breather hose connection.
Hi Matt,
Hose is about 7/8" ID, barb is ~1/2" OD. Haven't found a solution yet.
Thanks,
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
bobplyler
Post by bobplyler »
124JOE wrote:yes and the holes are smaller
so if i use a base off the adfa
it will be the same as the adfa
responce wise
I can state from experience that that isn't so.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
124JOE
Post by 124JOE »
ill wait for a spacer
im going with a filter from a mower on that hose
like others did
but this is from tartin18 he used an adapter on a hose
this is from fiat 218
jsab
Post by jsab »
I used a piece of 3/4" OD hose. Slip it into the 7/8" hose and clamp. The inside diameter of the 3/4" OD hose is close to half inch for the fitting.
124JOE
Post by 124JOE »
did you use this?
its a bit small IMHO
opus10583
Post by opus10583 »
Thanks again everyone!
Here's were we are as of 4:45pm EDT: Studs came out with out a hitch, studs went in without a crossthread.
EMPI universal linkage kit is useless...
The kit's ball joint assembly wants a cable and the ball joint head's ferrule is too large for the 1978 124's linkage rod.
...It's going to be a long day at the parts and harware stores tomorrow.
See also; my "Swimming Camshafts" thread for another "Great Moments in 'WTF?'":
http://www.fiatspider.com/f08/viewtopic ... 04#p136374.
Thanks,
Mark
The linkage kit does not require a cable. The kit does include a cable connector, but the kit contains many more parts than needed for a single carb. It contains parts for a couple of different types of linkage connections, thus the "universal" label.
124JOE
Post by 124JOE »
i hope this pic helps you opus
the one closest is the 32/36 and is set up for a 1800
i was told
opus10583
Post by opus10583 »
So Cal Mark wrote:The linkage kit does not require a cable. The kit does include a cable connector, but the kit contains many more parts than needed for a single carb. It contains parts for a couple of different types of linkage connections, thus the "universal" label.
Thanks Mark, but nothing in the Empi kit fitson the FIAT-end of a '78 Spider
opus10583
Post by opus10583 »
124JOE wrote:[..]i hope this pic helps you opus
i was told
Hi Joe,
Thanks again, my old carb doesn't have the parts I need for the DFEV.
I've got a short-short-term solution going, only need to get 3miles, and Mark's kit on order.
Thanks again,
Mark
that's why the kit has two ball studs in it, so that each end can be installed. One on the carb, one on the bellcrank
opus10583
Post by opus10583 »
So Cal Mark wrote:that's why the kit has two ball studs in it, so that each end can be installed. One on the carb, one on the bellcrank
Hi Mark,
Your kit, which I don't yet have?
The Empi 43-0602-0 Uni-link Kit, which Empi and half the internet claim is all one needs, has one incorrect ball joint fitting.
I'm placing an order with you tonight, thanks.
Mark
opus10583
Post by opus10583 »
Got it in.
Linkage is, as the Brits might say, bodged.
Sounds great! Goes almost like it should (8:1 CR...). The 4-2-1 manifold and this carb on a '78 are the best esthetic and performance value for dollar I can imagine.
Ciao,
Mark
okay, the Empi kit alone doesn't have enough parts. I somehow missed that you weren't using my kit
opus10583
Post by opus10583 »
So Cal Mark wrote:okay, the Empi kit alone doesn't have enough parts. I somehow missed that you weren't using my kit
No worries, order placed.
