Removal and installing emblems
Does anyone know how to remove and install hood and trunk "Fiat" emblems for a 1975 Fiat Spider? I am not sure if it is glued on. I haven't really checked yet but I want to do some research first before I attempt to remove and install them. Pictures or a video would be great. Thanks.
- 124JOE
Re: Removal and installing emblems
you need a 90 degree hook
push the pins out from the back side
Early style bronze wreath badges don't push in, they have tiny little nut-washer hardware on the inside of the hood or trunk that will easily snap off if not treated gently.
Getting the nut type hood emblem on is a PITA. I ended up using a little Blue tape to hold the washer and nut combo on the end of a nut driver socket, which worked pretty well. Blue tape stayed on the driver when withdrawn. Doesn't grab the washer/nut combo strongly enough to be a problem. Can't get your hands in there to hold things in place while threading it on.
