My wife drives the car and does not experience this. I drive it much harder and the problem shows up. I say that just to indicate that it's not that bad and has to be driven hard to be a problem. When transitioning from aggressive acceleration to compression braking deceleration, there is a noticeable shift in the rear end that has to be corrrected with slight steering input. I suspect a worn trailing arm bushing, but I had it up on jacks and couldn't move anything around, nor could I see any obviously blown bushings.
Am I on the right track?
Rear end yaw under accel/decel
Re: Rear end yaw under accel/decel
The trailing arms and panhanrd rod is where I would look. If it is something else I would like to know what it is. I would like to know what it is in any event.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
- maytag
I would say definitely trailing arm bushings.
try using a prybar on the rear bushings rather than by hand. Unless you're Superman, you can't exert nearly the same force as braking can
Typical symptoms of worn lower (long) trailing arm bushings.
Thanks for the feedback. I won't be able to get into it more thoroughly for a couple of weeks, but at least I know where to look.
