Replacing 28/32 with 32/36 DFEV - Need some advice
jsab
Re: Replacing 28/32 with 32/36 DFEV - Need some advice
Post by jsab »
Did you block off the EGR pipe from the exhaust manifold that runs to the head? You would get a lot of noise from that.
parsok
Post by parsok »
I have not yet checked the valve clearance, have to read up on how to do it. I did block off the exhaust port with a frost plug and a metal cover. I don't see any leaks. There was some smoke on the exhaust but I attributed it to the oil I used to fit the manifold and downpipe together. I'll see what it's like when it burns off.
Q - how long can I idle the engine without the coolant? 10-15 minutes?
124JOE
Post by 124JOE »
maybe 10 at first but if its still warm 5
but atleast fill the block
jsab
Post by jsab »
I didn't see in your posts if you removed your air injection system? Did you plug the head?
parsok
Post by parsok »
I did remove the egr and plugged the hole.
jsab
Post by jsab »
I meant the where the reed valves were on top of your cylinder head.
124JOE
Post by 124JOE »
on my 1800 head there is 4 hloes that come from EXH side if there not pluged on yours "if you ave them"
they will make alot of noise
they had tubes that all ran into one and into the exh manifold
parsok
Post by parsok »
Time for an update and another question.
I've put it all back together now. The clacking seems to have subsided a bit. I'm now using 20w50 as per some suggestions on the site. To answer 124Joe's question about the air injection rail - the 1980 2L head did not use a rail system only a EGR and I did plug it. No leaks of any kind that I can see.
I am now trying to tune the carb. I set the idle mixture screw turn turns out from base and the idle speed screw so that it was just touching the throttle plate (at least as far as I could tell. Not exactly sure as I can't see the contact as the screw is hidden in a spring). I started the engine and it ran like a tractor (just as the guide said it would!). I let it run for about 4-5 minutes then I turned the idle mixture screw in (righty tighty) until it ran quite nicely then backed it out to just before it started to run rough. The problem is it is now idling at about 1400 rpm. I played with the idle speed screw but it didn't seem to make a difference.
Any ideas? As an aside it seems to be smoking a bit. Can't tell yet if it is burning oil or it is incomplete combustion from running to rich??
the holes in the middle of the head are air injection, even though it's not a rail. The egr on a 2L was on the intake manifold and used the crossover in the front of the head. If the idle speed is 1400 with the speed screw backed out you could have one of several situations; the timing may be advanced, you may have a vacuum leak, the fast idle screw may be misadjusted or the secondary throttle screw may be misadjusted
parsok
Post by parsok »
Well I went at it again, reset the idle mixture and idle screws back to 'factory settings'. I checked the timing and it is 11 BTDC. Once it is warm I have it idling not too bad and at about 900 rpm ( a little high perhaps).
However, once the engine cools and I start it back up it runs like a tractor again until it warms up :?:
Any ideas are greatly appreciated.
124JOE
Post by 124JOE »
parsok wrote:Well I went at it again, reset the idle mixture and idle screws back to 'factory settings'. I checked the timing and it is 11 BTDC. Once it is warm I have it idling not too bad and at about 900 rpm ( a little high perhaps).
set your choke?
when cold it needs high idle
i just bought one so ill go thru the install soon
parsok
Post by parsok »
If I set the idle high so that it starts well, won't it maintain a high idle after it is warmed up?
124JOE
Post by 124JOE »
there should be a choke seting screw
ill look around
http://www.flickr.com/photos/71782262@N ... otostream/
theres a screw pointing upward tward the choke
loosen for more choke "higher RPM"
parsok
Post by parsok »
Woohoo - I think we have a winner :D Turned the screw in (right) and the rpm's picked up and it smoothed out. let it run for a minute or two then kicked off the choke. adjusted the idle speed screw and it seems to be idling nicely at 750 rpm.
Now the trick is to see if it works two days in a row.
Thank you very much.
Btw - what kind of fish is that? never seen one with molars before.
124JOE
Post by 124JOE »
i stole that pic from manona matt he is in HI
i also asked him about that fish
but cant remember what it is
