Replacing 28/32 with 32/36 DFEV - Need some advice
jsab
Re: Replacing 28/32 with 32/36 DFEV - Need some advice
Post by jsab »
You can buy vacuum block offs at your local auto parts store, they usually come in a variety pack. You can also get a crankcase vent filter that fits the crankcase vent hose if you don't want to run it to the base of your new air cleaner. If you do want to run it to the filter housing, you will have to reduce the hose size to get it to attach to the nipple on the air filter housing.
parsok
Post by parsok »
Thanks Guys, much appreciated.
Dave
parsok
Post by parsok »
I have taken everything off and put on the new intake and carb. looked good until I hooked up the throttle linkage and found I needed another spacer so the rod wouldn't rub on the cam covers :oops:
Question - I still have the charcoal filter installed. all of the top hoses are flopping freely but there seems to be a large hose connected to the bottom of it and I'm not sure where it goes - back to the gas tank? What should I do? Can I block of the top hoses and leave the filter anchored to the car or should I take it off and plug that hose or ??
Tx
jsab
Post by jsab »
I removed the charcoal canister and just blocked off the large hose.
the lower cannister hose goes to the tank, leave it connected. The large hose on top went to the float bowl. If you want to connect it you'll have to drill the carb top and put in a fitting, otherwise you can cap it. The small hose is a vacuum hose used to purge the cannister. Tee that into the small port on the carb for purging tank vapors
Kent124
Post by Kent124 »
parsok wrote: I still have the charcoal filter installed. all of the top hoses are flopping freely but there seems to be a large hose connected to the bottom of it and I'm not sure where it goes - back to the gas tank? What should I do? Can I block of the top hoses and leave the filter anchored to the car or should I take it off and plug that hose or ??
Tx
Yes, the bottom hose is a vent hose for the fuel tank. I would leave that one in place, block the others, and call it good.
if you leave the tank connected to the cannister, don't block off both of the other ports. You need to tee a vacuum hose to it to purge the vapors
124JOE
Post by 124JOE »
on my 78 theres three vent tubes that go into one via plastic connector
thats the big one on the bottom
if you seal off the charcoal can it will cause vapor lock
as for you guys who removed the can i bet you smell gas
or have V L problems
jsab
Post by jsab »
No, no gas smell, and no vapor lock problems, can has been off for 3 years.
124JOE
Post by 124JOE »
ok i was wrong
opus10583
Your car is a: 1978 CS1
Post by opus10583 »
Hi,
"Me too", sort of...
Replacing my '78's 32 ADFA with a 32/36 DFEV: How do I correctly cap/plug the engine-side choke coolant connection?
(I've got the Allison nipple-less pipe.)
Thanks,
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
124JOE
Post by 124JOE »
normaly you would take off a hose and put the other one on that nipple,making a loop
if you only have one then take a peice of hose 2"and fill one end with high temp black rtv silicone
if you tape near the end it wont get sloppy,remove the tape when still wet
let dry,cut off end 1/8"to clean it up then clamp it on the nipple
this also works for vacume lines
parsok
Post by parsok »
It's Alive :D
I got it all put back together sans all of the emission control junk. Looks a lot less crowded. Makes quite the clacking noise from the exhaust side. I see reading from the threads that this is somewhat normal. I'll try putting in some 20w50 and some zinc and see what that does for it.
Think I'll drive it this summer and then put in a 1800 head as the winter project.
Thanks to everyone for all your advice.
Dave
have you checked the valve clearance?
124JOE
Post by 124JOE »
is your exh gasket good or leaking?
