Trunk Floor
DocGraphics
Re: Trunk Floor
Post by DocGraphics »
The stock jack fastens on top the pass. wheel well w/ a strap & I'm getting that the tool kit fastened the same way on the drivers side (am I right) so I need access to them.
My 78 didn't have side panels like I made (79 & newer) but I like the way they look & protect, but need to figure a way to make them work for access to the wheel wells & the jack/tools without having to "unbolt them".
I have found some boat cover type twist fasteners that I think I can make work (seen elsewhere on this site), along with some sort of stops/hinges along the bottom edges to make them work.
All said & done, w/ carpet, I think this will be very capable of anything I wish to haul in the "VERY BIG" trunk we have, without sliding around & denting the inside of the fenders during a sharp (performance) turns.
Don Raugust
124JOE
Re: Trunk Floor
Post by 124JOE »
for a bottom hinge you can use an old seat belt cut to length and burn the ends so it dont unravel
whiterabbit
Re: Trunk Floor
Post by whiterabbit »
I've got an '81 with the boards warped as hell but there so I'm looking at some "temper board" scraps lying around. A good coat of varnish should seal them. I spotted some nice tan trunk carpet at the store the other day to cover them and the piece that is missing at the trunk edge/tail light area. Might be a spring time project after I fix the heater valve.. BRRRRRR!
124JOE
Re: Trunk Floor
Post by 124JOE »
so far i got some hard board
then traced it
then cut it
azruss
Re: Trunk Floor
Post by azruss »
I replaced my floor with 3/4" ply. also changed the way the cover came off so it left the section to right of the battery in the trunk. I used that section to mount a permanent tool box. the floor has been indestructable. used the car for many years as a work truck and have carried everything from hydraulic cylinders to 55 gal drums. (yes, it will fit in the trunk). also got rid of the factory jack and found a small bottle jack that would store in the corner of the tire compartment.
124JOE
Re: Trunk Floor
Post by 124JOE »
i sprayed a house once and hauled my paint sprayer in my car
you should have seen the looks that day down in the hood
speedshift
Re: Trunk Floor
Post by speedshift »
as usual great info & pics from all ! make it light weight, two pieces, hinge side panels to protect inner fenders, paper template to cut pieces ? does anyone have a template ? tks to all this subject ( is this a great site Mark ! )
