I don't know what mounting brackets hold what hoses and what holes in the frame house which hoses. Does one of the hoses go into the side wall near the fill tube and then up through next to the fill tube? I don't know. I would like to get all this done today. Thank you to anyone who can help quickly. I'm going to go buy some hose clamps. Wish me luck!
Here is a shot about as far as I got when I realized I have no idea where they go. Ha!
I need gas vent hose pics in trunk
Re: I need gas vent hose pics in trunk
is the skinny one off the fuel cap for water to drain?
- 124JOE
the small tube nearest the taillight is the drain
for water right? Does it just lead down to the ground basically?
Also I'm looking at this one way valve on the clear green hose. Where can I get one of those. I'm searching international auto right now and can't seem to pin it down. Or is there something similar I can grab at napa?
- 124JOE
jimmycakes401 wrote:for water right? Does it just lead down to the ground basically?
yes thru a tube to the ground
http://www.autoricambi.com should have them.joe
