Heater Valve
Heater Valve
Hello all - right now my heater core is bypassed because the heater valve was leaking (causing many problems with air in the system etc.). I'm going to replace the valve
Here are my questions -
-has anyone tried to replace the heater valve without taking the core out - it looks impossible to me, and
-should I take the core out anyway and have it tested or cleaned. I even thought buying a new one may be worthwhile
Thanks as always
Thanks as always
Ira Brown
1982 Spider 2000
1982 Spider 2000
Well - I made pretty good progress until I got to the second nut that attaches the valve to the core - the nut is up against the plastic (fan cover I guess) and I cant get a wrench or ratchet around it - is there some type of tool that can get a grip on that?
Also, the sensor wire is broken, probably has been for years - do I need that?
Ira Brown
1982 Spider 2000
1982 Spider 2000
- Contact:
As for special tools, I just used a good pair of vise-grips to snap the stupid plastic fin off of the fan cover. It made that upper nut alot easier to reach. One of the pipes need to be bent slightly to fit the aftermarket valve.
I did mine on a hot August day, contorted with my bum on the seat, my back supported by a folded gray military blanket (my back seat cover) and my feat straddling the headrest... oh and don't forget to wear safety glasses!
Brian G. Butler
Colby Village
Nova Scotia, Canada
'79 Fiat 2000
Colby Village
Nova Scotia, Canada
'79 Fiat 2000
Thanks to all the guidance I have successfully removed the valve. I'm going to try and post up a couple of picture later tonight, as the aftermarket replacement does not look similiar to the one I pulled out. INterestingly, the one I took out had no rubber washers in place.
Where I can use some help is getting the heater core back in the loop as I'm not sure exactly the right places to connect the hoses coming from the firewall back to the engine - there is a green hose which looks like the outlet, but I believe its the inlet.
Ira Brown
1982 Spider 2000
1982 Spider 2000
http://s217.photobucket.com/albums/cc94 ... valves.jpg
Not sure if this will work, but I'm trying to show an image of the after market valve compared to the one I removed - does it look like the standard replacement? The position of the control arm to close the valve seems different
Also, I've tried to show the bypassed core - I believe the green hose should run down to the pipe along the engine and the black to the top of the cylinder head. Does it matter which way they go?
http://s217.photobucket.com/albums/cc94 ... edcore.jpg[/img]
Ira Brown
1982 Spider 2000
1982 Spider 2000
Thank you very much Mark - its become clear to me that alot of the problems I've had with over heating were simply because of this heater valve and an old thermostat. This website has far more information than my mechanic, who i've totally lost faith in.
I'm going to continue a discussion thread I started in the spring to address the new water temp gauge I have now. The sending unit is wrong so the temp doesnt read properly (see mechanic above). This should get me back on track.
Thanks again
Thanks again
Ira Brown
1982 Spider 2000
1982 Spider 2000
