Update: now high-20's with proper jetting. 10 hrs. of 4,000 RPM from Nashville to Baltimore yielded 25+baltobernie wrote:Modified 1800. 20-22 MPG city or highway; doesn't seem to matter.
Whats your MPG?
Re: Whats your MPG?
Re: Whats your MPG?
I've been getting an average of 27-28 mpg when I run on non-ethanol fuel at 75mph, if the odometer is accurate. Over 30mpg if I poke around at 55mph.
1980 with Weber 32/36.
Re: Whats your MPG?
alfa romero ,32
fiat 28. i think
fiat 28. i think
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Whats your MPG?
A small update, as I had the dual carbs cleaned and rebuilt (apparently they were quite full of varnish).Redline wrote: ('71 Coupe, 1608, dual carbs)
1st tank after the rebuild: 7.9 l/100km (30 USmpg)
2nd tank after the rebuild: 6.9 l/100km (34 USmpg)
[/quote]
Sounds amazing for twin weber dual throats. What octane rating are you using ? Leaded ?
- Redline
- Your car is a: formerly a 1971 Fiat 124 BC Coupe
Re: Whats your MPG?
I use a mix. It can live with 98 RON (with or without additive, to he honest I skip it now because the engine anyway has hardened seats), but even then it will ping on inclines under load at lower revs. It's very happy on 100 RON (e.g. Shell V-Power). Seems to make no difference on economy, whether I use 98 or 100, just on driveability. Typical RON available at the pump here is 95/98/100 (only Shell and BP).
As far as I remembers, the V-Power is beyond what you can buy at the pump in North America or most of Australia / New Zealand (but I could be wrong).
http://en.wikipedia.org/wiki/Octane_rating
http://en.wikipedia.org/wiki/Gasoline
In the US, octane ratings in unleaded fuels can vary between 86 and 87 AKI (91-92 RON) for regular, through 89-90 AKI (94-95 RON) for mid-grade (European premium), up to 90-94 AKI (95-99 RON) for premium (European super).
(R+M)/2 AKI rating in US / Canada:
http://www.124bc.com
Re: Whats your MPG?
At 55 MPG with 93 Octane it is about 28. At 70-75 MGP with 93 Octane about 25-26. If I run anything less than 93 Octane and if i stray away from shell I will get a slight ping in the engine.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Re: Whats your MPG?
Redline in Switzerland must be doing something special. His 6.9Litres per 100Km equates to 40.76 miles per imperial gallon. I imagine that Switzerland is some distance above sea level too ?
I know different oil sourses have different callorific values ( does not have the same end user energy).
My best ever run over about 350km at night on easy running open roads, not going much over 100kph (62mph) was about 32-33mpg (imperial) or 8.5 Lper 100k which I thought was pretty good. Thats in a Fuel Injected 2000, starting at about 50', up to 700' & back to sea level.
- Redline
Re: Whats your MPG?
The subsequent three tankfuls were 8.0, 7.2 and 7.3 l/100km. I myself didn't do anything, but it seems my mechanic is a wizard.
The 8.0 tank was driving up to the mountains and back (500m - 1600m). The rest is at 500m, +/-
I don't know how I'm getting these numbers, I'm just enjoying the result. It must be that ultra-slippery Coupe body.
Re: Whats your MPG?
I'm getting about 23-28, 99% in-town, to and from work driving and cruising. I'm at around 5400 feet. Bone stock '79 2L w/ the crappy carb.
Re: Whats your MPG?
the 72 i have with a 2l, 23 on the highway, i thought it would get better
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- pressonregardless
- Your car is a: 1974 Spider
Re: Whats your MPG?
My '74 with 1800, Points and DMSA carb give about 22-24 combined. Just running round town and a little country drops to about 20 or so. No mods, 107K miles on original motor. Timing set about +5' I just put new points in, Dwell set to 55-56' (.017in) and timing set back to about 0' TDC. I want to try out this setting for best all around performance. I have never heard a ping, even below 2000 rpm. For awhile I ran about 12' BTDC timing and had great bottom end performance, but nothing after about 4000 (not that there really is now, I just don't rev it too hard).
1974 Spider, 1756cc, points & Carb, 118K California miles
Re: Whats your MPG?
Geez... You guys get some darn decent gas mileage. My '74 1800, 50k orig miles, shaved port & polished head, stock carb with larger jets... I only get 17mpg no matter how I drive. Although The car runs fantastic and has plenty of get up & go, but the gas mileage sucks!
Re: Whats your MPG?
Same here.aj81spider wrote:I have an 81 FI that gets a mix of highway and country road driving. Average MPG is 23-24.
