4 month lifespay for iggy coil???
WYSpider
Re: 4 month lifespay for iggy coil???
Post by WYSpider »
Yes, no reason to keep a bad coil around :)
The coil is the original from 1980 and has close to 85,000 miles on it. Never had a problem with it but am planning a long trip and didn't want to have to hunt around for parts if I broke down. The old, working parts, are kept in the trunk just in case.
coils do get extremely hot, there has to be some result of creating 10,000-20,000 volts hundreds of times per minute. Oil filled coils should be mounted at an angle, the hottest point is the - post. If it's upright, that post is not covered with oil and will overheat
WYSpider
Post by WYSpider »
So Cal Mark wrote:Oil filled coils should be mounted at an angle
Wondered why my new one looked cockeyed after install.
puddin
Post by puddin »
thanks mark== this seems logical and it's and easy fix
124JOE
Post by 124JOE »
yes thats a good one
anyone else?joe
puddin
Post by puddin »
damn it == tilting coil to a 2 o clock postion didn't help???
gonna check amperage flow through pos terminal
puddin
Post by puddin »
get this- 4 amp constant draw-- disconnected opitical pick up and plug wire and 4 amp draw from eith +pos or -neg terminals
so now i know why it's getting hot
is this excess amperage
shouldn't it go to 0 zero (amperage no flow) once the primary windings are saturated?????
puddin
Post by puddin »
iap reccomends .7-.81 ohm primary -- and 10-11K ohm secondary coils
i suppose this is with a ballast resistor
majicwrench
Post by majicwrench »
Coils will pass current constantly as long as the (-) side of coil grounded.
Four amps sounds about right. And you will have 4 amps going in the pos and 4 amps coming out the neg.
Checked my old 64 Chev PU after a half-hour truckin around. Old 6cylinder, coil, probably original, mounted straight up in original bracket mounted to block.
Hottest point...bottom of coil, 180 deg
Neg term 148
Pos term 133
Engine block, 188
Head, 200.
Its a hot day, hot for Libby anyway.
This is with a non-contact thermometer.
Taking my fiat into town this eve, will check it's coil too.
puddin
Post by puddin »
F*^* it
it's running good so im leaving it alone till it gives me problems in 4 months
gonna get some beer and watch it rain
zachmac
Post by zachmac »
Call me crazy but do you have it wired backwards? I know it is unlikely, but???
Coils are just transformers. Wired correctly they step voltage up, wired backwards they step it down. The WILL operate backwards but very quickly overheat and fail. I learned this the hard way on my 1970 XKE. Car would start and run for a while then quit. Drove me crazy until an old guy I knew told me about when he was a teenager and he and a girl picked up her dad's brand new Rolls in NYC to drive it to CT. Got just outside the city when it died. Coil was wired backwards at the factory! Swapped the + and - leads and went on their way. Same thing on my Jag.
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
manoa matt
Post by manoa matt »
1970 XKE
brand new Rolls
my Jag
Starting to see a pattern, those British were never that good at wiring.
the blackouts in London during WWII weren't intentional 8)
majicwrench
The coil on my fiat was wired backwards for YEARS and never gave me any trouble. I hooked it up to my scope a month ago and saw it. Switched wires around, still runs good. IN the good ole days when most cars had external coils, we would see the occasional coil hooked up backwards. Running cars. And we just corrected the wiring. I'm not sure just why coils are designed to have polarity only one way, must be a good reason, but I don't know it. They seem to run either way.
Keith
Ken
Post by Ken »
When I first got my Fiat I went through a couple coils and wound up making a shield from a piece of thin aluminum sheet to keep away the excess heat it was getting from the headers and it seemed to work as I never had another coil burn up.
Hooking up a coil backwards will not make it step down, it will only reverse the electrical path of the spark at the spark plug and it does make a difference.
