What is the torque ft lbs for the pinion nut also should the crush sleeve be replaced also when changing the seal.
Nick
torque of pinion nut
- Your car is a: 1979 Fiat 2000
Re: torque of pinion nut
Oh forgot to mention the car is a 1978 spider 124.
- Your car is a: 1976 Spider - sold
I have a leaky seal too so I've done some research into the torque settings. I have not found a definitive source for the torque. I've seen one site that say 160 ft. lbs. I've also seen "mark the nut before removing and tighten it just past that mark" from someone claiming to be in the repair business for a couple decades.
The official manual says use a new crush sleeve and tighten until the pinion turn force is between 14 and 17 in. lbs. I bought a small torque wrench and plan to go this route. It does require complete teardown of the rear axle though
76 FIAT Spider - Sold
