Newer Speedometers
Newer Speedometers
To disconnect the newer Speedos from the cable do you need a special tool to release the plastic ring? I don't want to get too rammy with it and break the plastic, I need it again. Or, is the plastic fitting a nut as well? Also does anyone know why the Trannies went from the early gear ratios then switched back again after 1980. Is the older set of ratios a better fit? Can the earlier ('74) trannies be mated up to a '80 motor for better performance?
on the speedo cable, slide the ring back away from the speedo. the cable will then simply pull off of the speedo. Trannies can be swapped between all years/engines. The one exception is the 1438 motor used a smaller bellhousing. But bellhousings can be swapped.
Diff ratios changed in 79, so that might explain why ratios changed
