DocGraphics wrote:The horn button comes off by slipping a blade or thin screwdriver under the retainer ring @ the metal spoke area then pry it up carefully to pop it off & then the wheel is held on by a big nut, 15/16" socket works great, then wiggle the wheel off off.
Thanks, Doc! Did exactly as you suggested this weekend and it worked like a charm. NOS wheel installed and looking good!
