rear sway bar
124JOE
rear sway bar
Post by 124JOE »
hey guys im going to fix my pass side mount it seems to have sliped out
as it has before but not this much any more and i would have lost its pearch
:roll:
124JOE
Re: rear sway bar
Post by 124JOE »
update---
it was lose because of the 3 1/2 u bolt wasnt threaded long enuff
so i used a washer and lockwasher under all nuts
Kevin1
Re: rear sway bar
Post by Kevin1 »
You might want to move that brake line outside the u-bolt while you are in there.
124JOE
Re: rear sway bar
Post by 124JOE »
its all good its been on there for seven years
it seems to have all the space it needs
Razooli
Your car is a: 1982 Fiat Spider 2000
Re: rear sway bar
Post by Razooli »
On mine, I found the plate the U-bolt goes thru bends very easily and no matter how much you tighten the nuts, the bracket always loosens up. I put a couple pieces of thicker steel shim between the piece that hits the axle and the plate and no more loosening.
Lynn Shuler
1982 Spider 2000
Remember, this hobby is supposed to be your therapy, not the reason you need therapy.
124JOE
Re: rear sway bar
Post by 124JOE »
THANKS
SanRafaelFaz
Re: rear sway bar
Post by SanRafaelFaz »
124JOE wrote:its all good its been on there for seven years
Have you noticed an appreciable difference with the rear bar? I'm thinking off adding one, but my car bites so well into tight turns now, that I can't imagine what more it could do for it. :?
SanRafaelFaz
Re: rear sway bar
124JOE wrote:hey guys im going to fix my pass side mount it seems to have sliped out
:roll:
Where the front forged (flatened) ends of the bar attach to the frame, are there already holes in the frame, or did you have to drill them? Are they held to the frame with just cinching bolts, or do you have to blindly reach up and in and fasten a nut?
Thanks!
Razooli
Re: rear sway bar
Post by Razooli »
SanRafaelFaz wrote: Where the front forged (flatened) ends of the bar attach to the frame, are there already holes in the frame, or did you have to drill them? Are they held to the frame with just cinching bolts, or do you have to blindly reach up and in and fasten a nut?
Thanks!
Check out these links for the instruction sheet and diagram. You have to drill two holes and slip a u-bolt inside the frame. The end-link bracket attaches to the ends of the u-bolt.
http://www.flickr.com/photos/12662916@N ... otostream/
There are also a bunch of photos of my bar there.
Lynn Shuler
1982 Spider 2000
124JOE
Re: rear sway bar
Post by 124JOE »
yes it goes just like the links show
to locate i had to fully asemble the sway bar kit and mark it
then remove parts of it drill then reasemble it
all and all id rather buy the bigger front sway than the rear
manoa matt
Re: rear sway bar
Post by manoa matt »
"all and all id rather buy the bigger front sway than the rear"
Not if you knew what was involved to mount it, and some of the resulting problems.
124JOE
Re: rear sway bar
Post by 124JOE »
well then mabey not
SanRafaelFaz
Re: rear sway bar
124JOE wrote:yes it goes just like the links show
I have one in the front. I don't remember ever having it put on so I can only assume it came with it, and I'm the original owner. :? So does that negate any effect adding a rear one might have?
manoa matt
Re: rear sway bar
SanRafael, you are likely talking about the stock front sway bar. Here is a write up on adding an aftermarket bigger front sway bar: http://www.ovingtonpaint.com/fiat/id4.html
124JOE
Re: rear sway bar
Post by 124JOE »
no te car hadles like a dream /powers through cornners. you know get one if ya want to
