So I am coming from a full size AMC Jeep Cherokee Chief and into an 82 Fiat Spider 2000 FI. Wow, what a different ride for sure! I wasn't sure what to expect, but I am hooked! I brought this car home about two months ago and here is what I have done so far:
Front Brake hoses, lines and calipers
Center drive shaft bearing and bushing
turbo muffler
exhaust camshaft (#1 lobe was rounded right off?)
timing belt
alternator belt
spark plugs and wires
battery
alternator
This represents about $700+ in parts and about 15 hours of labor. There is another "hollow" sound coming from the front when I turn right. Sounds like the wind howling loud, but it is definitely a metallic sound. Steering component? wheel bearings, etc? Any ideas what this could be? only does it when I turn right.
Thanks for any help or suggestions.
New to this forum
- 124JOE
Re: New to this forum
wheel berring
- Your car is a: 1980 CS0 + 1985 Volumex
Treat the ol' girl right and she will treat you well too (at least sometimes...)
Welcome
Welcome
1980 CS0 FI
1985 VX
1985 VX
Hello and welcome! You sure have a different view of traffic down there now, don't you!
Since you've done some front brake work, I'd suspect a dust shield rubbing. Sound like a stick rubbing on the edge of a cymbal? Look for some shiny metal somewhere in the vicinity.82FIATSPIDER2000 wrote: There is another "hollow" sound coming from the front when I turn right. Sounds like the wind howling loud, but it is definitely a metallic sound.
