It's not a new top. It's quite old. It was removed when the previous owner had the car painted. The body shop put the top back on and now it's a bit out of alignment.DUCeditor wrote:That is not uncommon with newly installed tops and not necessarily evidence that it was improperly installed. If the top is installed so that it easily clips into place it'll be too loose once it has broken in. This is true for many soft top cars, not just Spiders. Among Miata owners there is a "rule" that a newly installed top should not be lowered for at least two weeks.
Tim.
