Lowering my Spider
ajnsbdfr
Lowering my Spider
Post by ajnsbdfr »
Has any one Lowered there Spider?
I have a 1980 Spider, would like to drop it a couple of inchs, without screwing up the ride to badly.
I have seen after market springs that would drop it 1", but I'm not sure that will help the high water look.
Anybody have any sugestions?
jfrawley
Your car is a: 1982 Spider
Re: Lowering my Spider
Post by jfrawley »
Free up your time for a couple of days and cruise through this group of posts.
http://www.fiatspider.com/f08/viewtopic.php?f=14&t=4965
John Frawley
Frederick, MD
1982 Spider
http://www.dcfiats.org
harold
Post by harold »
You can always cut the springs...
azruss
Post by azruss »
the handling got screwed up when Fiat jacked up the ride height. 3 ways to go. hit the usual vendors for springs, relieve someone of their early spider springs (I put 71 springs on mine), or cut your current springs. been much discussion on mirafiori.com on this subject and how to actually do it. cutting the spring will give you a slightly stiffer ride. (same weight distributed over fewer coils).
azygoustoyou
Post by azygoustoyou »
I have uncut springs for $25 if you want to experiment. :mrgreen:
corujoxx
Post by corujoxx »
Take a look at this, is in spanish, but plenty of pictures and diagrams:
http://www.corujoxx.com/MIWEB3/clubfiat ... siones.htm
I´ve used shorter springs to lower my Spider, and added new Koni adjustable dumpers. The result is fantastic, much easier cornering, but too hard for bad roads. The springs came from Germany, about 180€ (240 $)
Hope it helps
