Update:
I used the measurements I got from Kevin1 & got the new holes EXACTLY where the old ones were, THANK YOU.
I drilled thru from the top side thru the bondo & new paint & they came out thru the old holes in the metal on the underside.
Got the used boot & hooks I got from George cleaned up & it mounted great!
Heres a few pics:
hooks mounted, cut gaskets from a waterproof outlet cover to use under them.
boot all cleaned mounted, still need to fix a snap on the drivers side & one of the hooks on the inside.
Now I need to figure out how to make it go around the roll bar nicely & find the straps for the top that go underneath.
Thanks for the help guys, Love this forum. One project mostly completed, many more to go.
