Hi All,
Anybody run into the tie rod on the passenger's sider hitting the exhuast downpipe? What is the best way to fix this problem. I have a lowered '80 spider. Thanks!
tie rod hitting downpipe
the downpipe is the most difficult piece to build, I hear stories constantly about aftermarket header woes and clearance issues. I took great care with my design and clearance around the steering idler and tie rods and still everything has to be just so.
You may have to put a dent in your downpipe to get clearance. Can you post a pic?
I had a similar issue of close clearance, when I put a taller 1.6 and 1.8L engine in place of the original 1438cc. Mine actually was just the tied rod clamp bumping agaist the downpipe, and was resolved by loosening the clamp, rotating the clamp (not the tie rod -- or it will affect the toe in) to a different position, then retighten.
Alvon
Alvon
Guys -I have the same problem,and am looking for an answer also.I have a 1980 2liter (just put in engine) trying to convert to 421. The downpipe is from 1979 I think.The manifold not sure what year it is. I thought it was hitting on tie rod bolt,actually I just came in from the garage and dremeled the top of the extra threads off, its still hitting on the tie rod heat shield and nut? The motor mounts are new,so i dont think its a sagging problem.Also I noticed the down pipe wont align with the support bar from bottom of the transmission,its approx 1/4 inch lower than support? Are there different support bars?Motor mounts? Rob dont mean to takeover your post,but getting antsey on firing this thing up,Ted
Hi All,
Thanks for the replys. MarK, below are a few pics of the where the tie-rod has hit the exhaust. Is it my header set-up or the tie-rod? I had them replaced the same time my car was lowered.
http://render2.snapfish.com/render2/is= ... 50,590,391
http://render2.snapfish.com/render2/is= ... 50,590,391[/img]
Sorry, links are not working properly will need to cut and paste.
