Convertible top update
baltobernie
Re: Convertible top update
Post by baltobernie »
LStevens wrote:Baltomario, I'm sorry to disagree with you but I'm pretty sure the photo you provided (black top) is a squared top and NOT a round top.
Hey, that's Molto Mario not Balto Bernie :D
My top is definitely the rounded one. The photo angle is directly on the corner; for better comparison, I probably should have shot along the windshield frame.
dartme
Your car is a: 1970 fiat 124 spider 1979 2000 spider
Post by dartme »
I'm sure you can get the lower price just call Greg at Germanex and tell him your on the Fiat forum.
1970 124 sport spider
1979 2000 spider
Coyote2000
Post by Coyote2000 »
I ordered a new tan pinpoint top from germanex a few days ago based on this thread and the pics (Greg was awesome to deal with, btw). Much rhanks to Craig and LStevens and everyone - you all saved me a ton if research and a huge pile of $$ (some of which i donated to this site). Viva fiatspider.com!
marka206
Post by marka206 »
Just ordered a new top from Greg at Germanex for my newly acquired 81 spider. Great guy , a pleasure to deal with.
Next I need to order a master cylinder as the brake pedal just goes right to the floor with no resistance ,and there is no sign of fluid leakage, and the reservoir is full. Wheels all seem to turn freely, so I'm thinking it's the master cylinder. Has anybody else had this problem, and was that the fix?.............Mark
mdrburchette
Post by mdrburchette »
Is this a new to you car? Have you tried bleeding your brakes and changing the fluid? Sounds like there's air in the system somewhere.
marka206
Post by marka206 »
mdrburchette wrote:Is this a new to you car? Have you tried bleeding your brakes and changing the fluid? Sounds like there's air in the system somewhere.
marka206
Post by marka206 »
Yes the 81 spider is new to me, and I have not tried bleeding the brakes yet. I did order a new master cylinder and was about to pull the old one out. Anybody know a trick to getting the fittings off the master cylinder without rounding the nut heads?
ORFORD2004
Post by ORFORD2004 »
Yes, use the special 10MM brake wrench whit a slot for the brake line.
roy
Post by roy »
I just bought a 79' spider and have a question about the top. Is there a liner on the inside that covers the hardware or is it just bare? If you have any pics that would be great. thx
124JOE
Post by 124JOE »
the cheap tops have no liner
they do have strips that wrap around the bars with plastic covers that slide over the strips
as for the pricey ones i dont know
boogiedude
Your car is a: 1978 spider 1800
Post by boogiedude »
No tops for the spider have headliners. It wasn't designed that way, and you should be glad. I install tops with headliners t least once a month on old mercs or VWs and they are a PITA and add little to the looks of the car. Wasted money in my mind.
roy
Post by roy »
Thanks for the info, much appreciated
htchevyii
Post by htchevyii »
ORFORD2004 wrote:Yes, use the special 10MM brake wrench whit a slot for the brake line.
If you can, clamp vice grips onto the flare wrench to keep it from spreading.
Trey
HersheyPAGreg
Your car is a: 1980 Spider
Post by HersheyPAGreg »
I recently bought the Germanex vinyl top ($217.50) and I really like it. I had a local upholstery shop install it about 2 weeks ago. Thanks for the advice Craig (ga.spyder).
ga.spyder
Post by ga.spyder »
Looks great! Glad it worked out
Craig Nelson
Fling It Around Turns !
