Sorry I've been off the board for a while. Had to make the move from Daytona to North Carolina. But that's a different story for a different time. Anyway, my poor little Spider almost didn't make the trip. She ran great the first half (actually getting 26+ mpg on the highway) but the got worse as the miles went by. Long story short I found that one of the point sets had lost its gap or was worn enough not to open as the lobes passed under it. I adjusted it (without a gap gague) just enough so she finished the trip. Got to NC and figured might as well change the points and condensers (two of each) while I was in there. Went to install them but I could not tap the starter and get the distributor to stop at the top of the lobes. So I got it as close as I could and then turned the distributor. I gaped both sets of points to 0.016, then turned the distributor back to about where I started. Try to start her and so far all I have got is a massive backfire from the exhaust.
My question, what did I screw up this time?
