Well boys and girls I have just finshed one side of my 1979 fiat spider new sub frame new floor, iner fender, outer fender and rocker panel. 38 hour of welding fitting and finshing the floor. Just have to do the body on that side. Then flip the car around and do the same to the other side. Sorry I'm still try to down load pictures. I'll learn.
Regards Glenn.
1979 fiat spider
Re: 1979 fiat spider
Just an up date, It's been 3 months working on the fiat. I really recommend that when replacing the the floor just go and put new
sub frame in instead of trying to save the old one. Does anybody know what to use for fuel line running threw the inside of the car?
Regards Glenn.
Regards Glenn.
- cincifiat
- Your car is a: 1980 Fiat Spider Automatic
I found a leak in my fuel line just before I parked it for the winter. I'm still in the process of changing it but I'm using Poly armor steel lines
Ray
Ray
Thanks Ray, I'm going to run stainless steel lines that I found at work.
